- DrewEExplorer IIII don't rotate the tires by position, as most others, since their lifespan is not limited by treadwear in any way.
I do rotate the tires around their axis every single time I move the motorhome; failing to do so leads to very rapid and uneven treadwear (and very bad gas milage). :B
I just got back from the tire store an hour or so ago to price out a set of tires, as chance would have it. I probably would have waited another year, but had an unfortunate incident with a curb that put a nice deep divot in a sidewall...so rather than have a single mismatched tire to contend with (and trying to figure out how to distribute the others sensibly), I figured it was time. The tread still looks practically new. - TrackrigExplorer IINo, I don't rotate them regularly or at all. They're wearing nice and evenly back there.
Bill - CloudDriverExplorerI rotate the front tires with the spare to give the spare some use. The rear duals stay where they are until new tires are needed.
- BruceMcExplorer IIIMost people don't rotate, nor even have them rebalanced.
However, not being most people, I rotate when I have 'em rebalanced at around and interval of 10Kmiles. As the '99 ford chassis has identical wheels on all 6 positions, I rotate thus:
Left front to left outside dual
Left outside dual to left inside dual
Left inside dual to left front
Likewise for the right side. - path1Explorerhttp://www.tirebarn.com/services/tire-rotation
This article has good info and a good pic of dually rotation and also puts your spare into the mix if you want to.
I'm like others and will "age" age out first. - dbblsExplorerI have rotated side to side but decided it was not worth it so I have quit doing this.
- rvtenExplorerNever
- BobboExplorer IIIConsidering that the tires will age out long before they wear out, I don't rotate my tires.
- NRALIFRExplorerThe two duallies I have owned seemed to wear the rear tires pretty flat and evenly, so I saw no reason to rotate them. The front tires I would rotate side-to-side if I thought they needed it.
:):) - bighatnohorseExplorer IIOnly move them side-to-side so that they run in reverse rotation.
Given the nature of the rims, a full rotation would require taking the tires off the rims.
And that's just asking for trouble X6 - especially when some mechanic is doing it for you.
I ran 80,000 miles on the first set of tires doing it that way. Not planning to change now.
