Pops, most people don't rotate the tires on a coach like yours. You never want to change the direction of travel on a radial (fronts) and you need to keep the rears matched to their original partner. It can be done, but is not cost effective. Keep a close eye on your front tires making sure the air, alignment and balance are correct. Typically, they will need replacement first, but you can then break up the cost of tire replacement over a couple of years.
I've owned a dual rear wheel coach of some kind or another for over 24 years. Last year was the first time I was able to rotate the fronts to the tag position on my coach (my first tag axle RV). Obviously this doesn't pertain to your coach, but shows probably the only time the fronts can be moved around without costing a fortune and changing the direction of travel.
