pnichols
Aug 06, 2016Explorer II
rdhetrick wrote:
The more I think about it though, I think I've got the wrong idea. A narrower tire would just mean a higher PSF to the road surface.
Also .... a narrower tread width (in the front steering tires) helps a bit in reducing "steering wander". The vehicle seems to track straighter with less constant correction effort by the driver.
I've learned the above over the years .... starting with my first new car (a Mustang fastback). Big fat tires sure "looked good" on it ... but it tracked and drove a lot better with stock tread width tires on it! My personal opinion is that narrower tires - on hard surface roads but with a couple of inches of slush or snow in their surface in the winter - "push through" this top slippery layer better so as to be down onto the hard surface underneath. This would be due to the increased pounds per square inch of pressure for each square inch of tread contact surface.
Our Class C is now on it's 2nd set of 215/85R16E tires after changing from the stock 225/75R 16E tires that came on it new. Both sizes have the same load rating, but the 215's have a Green X rating (less rolling friction), and are a bit taller for a higher overall gearing - thus providing slightly improved fuel mileage along with about 0.6 inches of higher ground clearance everywhere (unlike lifted vehicles - which only have higher body ground clearance but not always more running gear ground clearance).
Since the 215's also provide more clearance between the rear duals, better air ventilation between them is probably going on - resulting in longer hot weather life.
All of the above are very subtle advantages, but since their load rating is the same ... I figure why not use them instead.
