IAMICHABOD
Aug 06, 2016Explorer III
rdhetrick wrote:
How do your GAWR's compare to mine? Mine is a 32' model, I'm wondering if it's a higher gross weight than yours.
Front GAWR is 4600 lb,
Rear GAWR is 9450.
Initially, My concern with going with a narrower tire is a reduced load rating. The more I think about it though, I think I've got the wrong idea. A narrower tire would just mean a higher PSF to the road surface.
I suppose if the tire rating X number of tires per axle is more than the GAWR, I should be ok?
My Gawr is the same as yours, it is on the Workhorse Chassis.Yes you will be OK with the 225/75/R16.
The offset on the Chevy wheels is a bit larger giving a wider stance and better handling than the Fords so you can run a wider tire with no problems.
Have you weighed your rig? It is important to have these axle weights to get the right air pressure for the load on the tires.
You can use This Table for that.
38,781 PostsLatest Activity: Aug 12, 2026
