pnichols
Dec 01, 2015Explorer II
I wonder why a foam ring (of very high quality durable and stiff foam material) of a little less diameter than the tires and a little greater diameter than the rims couldn't merely be installed, after removing the outer tire, and then compressed into place "forever" as you reinstall the outer tire and tighten the lug nuts?
This ring would of course flex all the time with the sidewalls while at the same time nearly 100% prevent the wedging of rocks in between the tires.
