wny_pat1
Oct 04, 2013Explorer II
If the tire has a smaller diameter, yes your mpg will be lowered, and your speedometer will be just for a bit off. And the tire you are asking is the proper swap and should work just fine. You will probably never notice any difference, and the tires he recommended should improve your motorhomes handling.
