bshpilot
Aug 11, 2014Explorer
1st i don't use a laser thermometer, a laser thermometer is only good when you're stopped....and on a long ride we might rack up 8-12 hrs between stops.
My TST tpms, pressure/temp monitoring system has registered 165* in stop an go traffic on 105* days
ive also seen tire temps drop quickly (to near ambient air temp) with the slightest bit of rain.
I have also noticed slightly higher temps on the tires closest to my generator (when i run the generator).
I wonder at the stops you use the laser thermometer are you ask checking the tire pressure ? Tire pressure can effect tire temperature.
with a TPMS system you know both - realtime, rolling or stopped.
38,783 PostsLatest Activity: Sep 09, 2026
