travelzoo
Aug 11, 2014Explorer
Alfred622 wrote:
I got an IR thermometer "gun" and started using it on this trip for the first time. I'm not sure what I'm looking for. After an hour of 60mph driving in 70 degree F temperature, I pulled off the road and measured the dual rear wheels.
Both outside tires (sidewalls) were 108 degrees, and both interior tires (sidewalls as best I could) were 111 degrees. Front tires were 107 degrees each.
1. I'm assuming these are all pretty close so nothing bad stands out -- Is that correct?
2. I'm assuming the 3 degrees difference between rear outside and rear inside was due to less air circulation for the inside tire, but that is ok? Would YOU agree?
3. I've searched forums for tire temperature interpretation, and only found one comment to beware if the tire temp gets more than 60 degrees above ambient air. Are there any other rules-of-thumb that YOU use?
4. I assume we're most concerned about significantly different hot temperatures. When do YOU get worried: 1 tire 10 degrees warmer, 20 degrees, 50 degrees warmer than its neighbors?
Thanks so much for your advice. I'm hoping we can reach some consensus that will be valuable to many people looking for Tire Temperatures!
Where are you buying these thermometers and at what cost??
38,783 PostsLatest Activity: Sep 09, 2026
