kab449
Aug 11, 2014Explorer
When I had my 40 Ft fifth wheel it was equipped with tst pressure and temp sensors on each tire. In 90 degree air temps and 60mph they would all register in the 130 to 140 degree range at 100 to 115 psi. I think your readings are in the safe zone. My tst system was calibrated to only sound an alarm if the temp exceeded 150 degrees. Load range G Tires good for 3750 lbs each.
It is on my to do list to equip my Class A with the same system.
38,783 PostsLatest Activity: Sep 09, 2026
