ArchHoagland
Aug 11, 2014Explorer
I check my tires on the coach and toad with an IR gun every time I stop. There is no perfect temperature, it's all dependent on several variables.
What I'm looking for is a tire that is significantly hotter than the rest of the tires. As Old-Biscuit said 15 degrees would be a concern.
Wind direction, sun, generator running, etc all play a part and you will see a pattern after many checks. I shoot my rear end on occasion. Always 155 to 165 degrees.
I also shoot my brakes occasionally. Workhorse had a problem with calipers and even though I've had the recall done I still check them. Toad tires...fronts are always warmer than rears on mine by about 5 lb.
The other important thing that occurs while I check my tires is that I check for problems such as awning coming loose, tow bar assembly still all connected, etc. Plus doing a walk around gets you some much needed exercise.
38,783 PostsLatest Activity: Sep 09, 2026
