jadatis
Aug 12, 2014Explorer
What Topic starter did by measuring the sidewall is to my opinion the best way to determine the inside-air temperature of the tire.
This because the isolation of the rubber is the least on that spot.
A TMPS mostly measures something between the inside and outside temperature , and already someone wrote that it gave colder when raining.
What happens when tires are roling when driving.
Every segment of tire bends by deflecting about 10 times a second, and produces heat energy.
This is transported by the inside tire air to the rimm and thinner parts of the tire ( sidewall middle) where it is transported to the outside tire.
so the inside tire temp says something about the isolation of the tire.
The spots ( or better rings) of the tire that produce the most heat by the most bending of the rubber ( heal of tire) must stay under a sertain temperature to prevent them from getting hard and crack at next bendings.
I estimate that critical temperature to be 130degr Celcius/ 265degr Fahrenheit) where hardening of rubber begins .
The tire is "backed " at 170 degr /340 degr F to set the right amount of sulfur bridges wich gives the tire its right balance of flexibility.
So it can be that the critical rings of the tire are 190 degr F and the inside tire temp is 115 degrees and outside temp is 70 degr.
There has to be a temperature difference to give over the energy.
38,783 PostsLatest Activity: Sep 09, 2026
