j-d
Jun 16, 2013Explorer II
The tires should not be inflated above 80 PSI Cold.
Crown of the Road will mean that the Inners bear a little more weight than Outers. They also run a little warmer. I'd say those two add up to a little more wear inside than outside.
Can you rotate the rears to get the Outers to the In and Inners to the Out? The tires should not be inflated above 80 PSI Cold.
You have negligible wear after 3yr/25000mi. Project out on that, and you won't wear them out before replacing on old age. Based on that, you can justify doing nothing you aren't doing already.
38,766 PostsLatest Activity: Jan 10, 2026
