S_NotFree's avatar
S_NotFree
Tires--Load Range Increase
Has anyone with a Class A increased their replacement tires, with the exact same size but gone up a load range higher? If so, did it make your ride much harsher?
I was going to do this, but the tire store is telling me that I am better off staying with the original size and load range because the coach was engineered for that tire and the ride would be harsh. However, to counter that argument, the higher load range tires are always more expensive and m Mfg's want to keep costs down.
Also, you could run lower psi in the higher load range tires that might offset some of the harsh ride.
Does anyone have any experience with this and your comments would be appreciated. In my case, Coach came with load range G tire and a H load is available.
Thx
  • You will be fine. IT is good to do that. Run one higher load range, but at the same pressure.
    ie, if your load range F oem tires called for 100#, go to G's, and run 100#. You get a tire with a little tougher carcass, better able to withstand punctures and road debris damage. Usually just a couple dollars more.
    I do that on my semi. ON the steer, I run one range higher. Those tires are close to their max rating, so it gives a little extra cushion. I keep the same range on the drives, because those are not loaded near as close to their max rating.
  • S'NotFree wrote:
    Thanks for all the replies...Since my Coach already had G's to start and the dealer had them in stock and it would have taken some time to get some H's in, I just went with the G's. mowermech, I don't think my coach is much more weight than yours. What pressure do you run in yours, same as the old F's or?
    The dealer had the load range G's in stock because they are the most popular for that size. Our 2001 Adventurer came with 245/70R19.5 load range F tires from the factory. When it came time to replace them we had a hard time finding the same size load range F tires.
    We wrote an e mail to Goodyear asking if load range G's would be an acceptable replacement. They not only said they were acceptable replacements, but recommended we go with them. The load range G's are far more popular should you need to replace one on the road. In addition they take the same pressures for the same load. Since they have a couple more plys they can hold more weight than the F's but require more air pressure to do it.
