wpatters1229
Jul 02, 2015Explorer
UPdate. Did one side of the rig today...too hot to work all day. Easy to take apart except I believe this is the first time the whole assembly has been removed as the locktite was a ***** to loosen up. Got the slotted and dimpled rotors with semi-metallic pads. Pretty nice. Now the only question I have is after putting the hub back on when I put on the wheel I see that the lug bolts are not centered in the holes. The wheel is centered but the lug nuts to not have any centering piece like on most of my cars. Is this normal? I know the lug nut torque is 140 ft lbs so I do not think it is a problem but it is just curious that they do not center left to right in the holes...hope that makes sense.
38,769 PostsLatest Activity: Apr 03, 2026
