j-d
Jul 02, 2015Explorer II
If you Chevy is like the current Fords, the wheels are HUB Piloted. Close fit between round hole at wheel center and a raised surface on the hub. The holes the studs pass through are larger than the studs, and the Nuts have a built-in Washer. For Ford, the studs are around 9/16" diameter and torque spec is 140.
38,769 PostsLatest Activity: Apr 24, 2002
