BigToe's avatar
BigToe
Tires E-350/450: Stock 225/75? Tall 215/85? Wide 235/85?
Tire Choices for Ford E-Series Cutaway Class C Motorhomes
What replacement tires did you put on your Class C motorhome built on a Ford E-350 or E-450 (aka E-Superduty in older rigs) cutaway chassis, and what were your reasons for your tire selection?
Did you stick with the stock tire size of LT225/75r16 ?
Did you go taller and skinnier, changing to LT215/85r16 ?
Did you go taller and wider, changing to LT235/85r16?
Did you upgrade to 10 ply rating Load Range "E"? (If you have an older E-350 originally specified with 8 ply rated Load Range "D")
Did you switch to European style 225/75r16C, such as what is specified for Euro van cutaways like the Transit and Sprinter?
Have you had an experience with any particular brand and model of tire for your E-350/450 RV that caused you to swear "never again"?
Do you have a particular brand and model of tire that is your trusted "go to"?
Thank you!
