BigToe
Oct 23, 2022Explorer
In addition to dual spacing clearance between the tires when loaded, changing tire sizes also results in changes to final drive ratio gearing, affecting acceleration, shift points, and gradeability in a given gear.
Still, I've read several stories (not sure if they are all from the same member or from several members) over the years on RV.net of Ford Class C owners changing to 215/85R16 (which actually results in more clearance between the duals).
Moreover, I've also read of at least one member who upsized to 235/85R16, as that was the tire size that Ford used on their SRW E series vans in the late '80's and early '90's.
I think that these owners were looking for a bit more ground clearance. They might have been looking for more weight capacity across the back axle too. I didn't pay much attention to the details when I stumbled across their posts, figuring that a keyword search would always retrieve their reasoning and results, whenever life presented a "need to know" demand.
Well, I was shocked at how sparsely few results revealed themselves in search, so I was hoping a fresh topic would unearth the considerations and motivations of E-350 and E-450 based Class C owners who have changed their OEM tire size.
Thank you for your words of caution on dually spacing.
