SJ-Chris
Oct 30, 2022Explorer II
BigToe wrote:
The Ford E-350 DRW and E-450 DRW E-Series Cutaway Chassis OEM 16" x 6" wheels that were manufactured in Canada by Accuride, identified by eight circular hand holes, are rated to 80 psi.
I haven't personally verified the wheel psi rating of the current 4 hand hole 16"x6" OEM wheels made by Maxion in Mexico, but have every indication to believe that they match the original wheel specification of 80 psi Max cold inflation pressure. I have personally verified the OEM wheels made by Accuride in Canada.
The interesting, informational, and arguably irrelevant aspect of the higher rating of the European Tyre & Rim Technical Organisation commercial tire standard developed for Euro Vans such as the Sprinter, Transit, Fiat, ProMaster, and VW equivalents marketed under various names depending on country... tires which we in the United States can identify as "C-Metric" tires (as very distinct from "LT-Metric Load Range C" tires... is that the "500 lbs." higher rating per tire in the 225/75R16C size is at 83 psi.
The stock wheels are only rated to 80 psi.
So the "margin" of weight capacity per tire must be reduced by the C-Metric tires rated capacity at a reduced pressure, which in this case is no higher than 80 psi.
Nexen doesn't offer any Load Inflation Tables. I even called Nexen tech support for this information, and spent 30 minutes on the phone with an Andrew at Nexen, who was not able to locate a Load Inflation Table for any of the five offerings that Nexen produces in the LT225/75R16 or 225/75R16C sizes.
However, most other tire manufacturers do provide load inflation tables, which let the tire user know the weight capacity of a given tire when inflated to less than the maximum psi that the tire is capable of withstanding.
Due to tire industry standards organizations, there is generally consistency from brand to brand in load inflation indices for any given specific tire size.
In this case, to determine how much additional weight carrying "margin" a 225/75R16C C-Metric tire has over an LT225/75R16E LT-Metric tire when both types of tires are inflated to the maximum pressure that the OEM steel wheel is rated for when cold (80 psi), I reviewed the Load Inflation Tables of several different brands of C-Metric tires in this size, and all tables from every brand checked were consistent with each other.
When inflated to 80 psi, a 225/75R16C tire is rated to support 3,085 lbs in single wheel configuration, as opposed to 3,195 lbs when inflated to 83 psi.
In dual rear wheel configuration, the C-Metric 225/75R16C is rated to support 2,975 lbs at 80 psi, as opposed to 3,085 lbs when inflated to 83 psi.
By contrast, the LT225/75R16E tire, when inflated to 80 psi, is rated at 2,680 single, 2,470 dual (per each individual tire).
So to stack the weight carrying capacity differences up neatly in a row:
3,195 lbs Single / 3,085 lbs Dual - C-Metric at 83 psi
3,085 lbs Single / 2,975 lbs Dual - C-Metric at 80 psi (OEM wheel psi rating)
2,680 lbs Single / 2,470 lbs Dual - LT-Metric at 80 psi
On the steer axle, there is a 405 lbs difference between C-Metric and LT-Metric at 80 psi, and on the drive axle, the difference grows to 505 lbs. at 80 psi.
Where the point in REDUCING the mental margin afforded to the C-Metric tire by ignoring the tire's maximum weight capacity at any pressure beyond the pressure rating of the wheel is arguably irrelevant, as all of these ratings exceed the weight capacity of the rear axles of all Ford E-350/450 cutaways, which range from 7,800 lbs to 9,600 lbs, depending on model and year.
However, it seemed to be an interesting observation to make... keeping the pressure limits of the wheel in mind.
Great info. I would summarize it (using your numbers) as:
225/75R16C rated duallies in the rear have a 80psi carrying capacity of 4 x 2975 = 11,900lbs
whereas 225/75R16E rated duallies in the rear have a 80psi carrying capacity of 4 x 2470 = 9,880lbs
Let's assume your rear axle was at a maximum weight of 9,600lbs. Would you rather have the E-rated tires that have only a 280lb margin, or the C-rated tires that have a 2,300lb margin? I would rather have the C-rated tires.
Next question: Does the typical RVer check your tire pressure EVERY DAY before they drive? I'm guessing 99% of people do not. (I have a TPMS so I can see always). What happens to these margins when the tires are actually at 75psi instead of 80psi? Or 70psi? Or 65psi? Answer: It spells trouble for E-rated tires.
What about when driving with your 75-80psi tires and you hit a pothole on the freeway? How much stress does that put on the tires? Seems like the C-rated tires would be able to handle it better.
Side note: Nobody should ever overload their rear axle, even with tires that can handle a heavier load.
Question: What % of RVers have ever weighed their RV fully loaded? We can probably agree that the answer must be "a very low % of RVers".
All of these reasons are why I choose Commercial rated tires with heavier carrying capacity on my 30' Class C RVs. (on my 23' Class C RV I have the E-rated tires, but might even upgrade those to C-rated tires next time they are needed "just because").
Safe travels all!
Chris
