Lobstah
Oct 20, 2013Explorer
I'd be more concerned with the body/frame of the coach. Parking over grass is generally a bad idea as it provides a constant source of moisture, and you're likely to end up with more corrosion on your undercarriage.
If it's the only choice you have, then I'd put a tarp over the ground/under the coach.
Jim
Jim
