Lobstah
Oct 21, 2013Explorer
stroza99 wrote:Lobstah wrote:
I'd be more concerned with the body/frame of the coach. Parking over grass is generally a bad idea as it provides a constant source of moisture, and you're likely to end up with more corrosion on your undercarriage.
If it's the only choice you have, then I'd put a tarp over the ground/under the coach.
Jim
Thanks for all the input, but a tarp under the MH? I would think that soaking water into the ground would be better the pooling water on top of a tarp, No?
thanks again all!
Not really. Water will run off the tarp and/or evaporate. The ground, especially ground with grass/weeds, will hold water like a sponge and create a very humid environment. Ask anyone who's parked a car or truck on a lawn for an extended period of time, or go ask a mechanic what happens when you park over grass.
Jim
