RoyB
Apr 04, 2017Explorer III
I tried all kinds of things for my 13,500 and did finally get it start up one time by providing 120VAC directly between the Honda and the air conditioner. It ran good until it needed to recycle again and then quit...
I did not play with any different type start capacitors...
I have run my 5000BTU window unit sitting inside my POPUP trailer with the rear of it outside over the edge and the window flaps duck taped around it... Worked like gang busters. I tried a test once on a 8000BTU unit and it started up on the ground outside the trailer so guessing it work ok as well...
Used to sit my 5000BTU A/C on a wood pallet outside a second door in my three room tent setup and it ran just fine on my 2KW generator.
Just need more grunt power for the 13500 and the 15000 BTU units...
Saw one guy running one of those TurboKool RV Motorhome Battery 12-Volt Evaporative Swamp Air Conditioning Cooler on his trailer once in the desert country. He said that worked great to but he had to keep water flowing all the time which was a big hassle thing. These work just like the swamp coolers back in the 60s in Arizona...
Roy Ken
Roy Ken
