steveh27
Apr 06, 2017Explorer
When I had to replace my ac in 2010 I got Dometic's high efficiency model, still 13.5k, and it runs well with the 2000. Everyone should get it when replacement needed, but you have to ask for it. They do not promote it.
The model then was 459530.701C0, but I think the number has changed.
Dometic's 459530 Hi-Eff 87 lbs. AC protection=15 amp compressor loaded amps=8.6 fan loaded amps=2.5 Total FUll load amps=11.1 amps.
Within one Honda 2000 output of over 13 amps.
Here's the real numbers for my high efficiency unit and operating it:
Here's my actual numbers:
I fired up my new Honda 2000 & plugged the Kill-a-watt meter into it. 126 volts. Then I plugged in my motorhomes 30 amp power cord with the proper adapter. I did not bother turning the breaker off to the converter based on my earlier analysis. The draw was 2.6 amps. Then I turned the AC fan on low. 4.5 amps. Then I turned the AC on and it went to 11+ amps and slowly climbed to 12.5 amps and had no problem running. In my motorhome the AC was nice & cold & the battery was being charged. All lights worked fine. I switched the eco on & had no problem. I switched the AC fan to low let it run for 1/2 hour. The draw then was 11.5 amps. Sweet. This high efficiency AC is worth every penny!
Air temp = 87 (hotter than before)
interior motorhome temp 95+
Gen only = 126.6 volts.
With my MH plugged in & converter left on = 126.2 volts 2.73 amps, 176 watts.
Turning the AC fan on to LO = 125.6 volts, 4.34 amps, 416 watts.
Adding the AC compressor
= 123.8 volts, 11.1 amps, 1210 watts. These slowly went up to 11.52 amps & 1250 watts.
Turned the fan on HI = 123.2 volts, 12.5 amps, 1381 watts. These numbers slowly drifted a bit higher.
Turned the fan back to LO & let it run 15 minutes. Nice & cool inside. 123.2 volts, 12.49 amps, 1400 watts, less than the 1600 watts continuous rating of the Honda.
My elevation is only 750 feet. Most people know at higher elevations the genny loses some hp so plan accordingly.
My solution won't work for some people, but it does for me.
Above from this thread in 2013:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26879670/srt/pa/pging/1/page/3.cfm
