willald
Sep 12, 2016Explorer II
mowermech wrote:Dutch_12078 wrote:willald wrote:
I actually live in the one state mowermech is referring to, I believe, that does require such (North Carolina). However, even with NC, the laws are soooo vague, its just about impossible to comply with it completely. Mowermech has the details, but NC basically says it has to be a system they approve of, but nowhere will you find anything saying just what types of systems they 'approve', hahaha. (right, mowermech?)
Gee, I hope my ReadyBrake system I use is one they approve of. :R Oh, wait, its not, since I can't engage or control it manually from the Motorhome. Guess I'm going straight to jail, now, huh? Hahahahaha. :)
ReadyBrake, M&G, etc. are NOT "brake systems" in themselves, so no approval should needed. They are simply "brake application systems" that apply the Federal DOT/NHTSA approved existing brake system on the vehicle that presumably NC approves as well. If they don't, that's a whole different issue...
This is the applicable portion of the NC law (20-124):
"(f) Every semitrailer, or trailer, or separate vehicle, attached by a drawbar or coupling to a towing vehicle, and having a gross weight of two tons, and all house trailers of 1,000 pounds gross weight or more, shall be equipped with brakes controlled or operated by the driver of the towing vehicle, which shall conform to the specifications set forth in subsection (e) of this section and shall be of a type approved by the Commissioner."
Note that the brakes must be "controlled or operated by the driver" and must be "of a type approved by the Commissioner".
Is a surge brake controlled by the driver? Is it of a TYPE approved by the Commissioner? Does the braking conform to Subsection (e)?
If not, it is apparently not legal in NC!
(sarcasm mode: on)
Ohhh, then I guess if you're gonna be in NC, unless your towed vehicle has a gross weight of less than 2 tons (4,000 lbs), you better make sure your supplemental brake system is approved by the Commissioner and conforms to Subsection e, or you're in trouble. :R
Whew! Sure glad my Ford Fusion's GVWR is around 3,800 lbs. Now I don't have to get my system approved by the commissioner. I don't have to use a supplemental brake at all if I don't want, and will still be legal in NC. :D
Will
38,769 PostsLatest Activity: Apr 24, 2002
