c_haggart@yahoo.com wrote:
I will be traveling to Alaska next year and am attempting to determine if it is worth towing the toad (Ford Edge crossover). I currently get about 7.2 Mpg with the toad, but have not traveled without it. What improvement can I expect in mileage without the toad? I have a Sunstar 26P, gas Ford V10.
With a gas engine, you should see about 1.5 to 2 mpg less towing your vehicle. You can't add that much weight and get the same mileage. It would be like going up a mountain without the toad. You will get less mpg than flat towing. If you are pulling the weight, same thing. A diesel engine might not effect you as much, but even with a diesel, when we towed our trailer with a Ford F250 diesel, we got 1.5 to 2.0 less mpg. It is just physics.
However all that said, take the toad. You won't regret it.
