Spizzer wrote:
I'm not real familiar with the Even Brake. But I believe it is designed to work with no power assist on your brakes. With the engine running I would suspect the unit would lock up your Jeep brakes to the point of the ABS kicking in.
Jeff
This is my thoughts as well. The brake boxes are meant to be used with the power brakes OFF. Therefore with the engine running, the brakes will be engaged as if the engine is off therefore causing huge problems, some that may be damaging to the Jeep. When you stop to pee, start the Jeep for a minute. Problem solved.
WW
