I have 2005 volvo v50 as my tow vehicle while coming home the vehicle started 2 flash the high beams when i stopped to find the problem i got into vehicle it sounded like morris code was going off und...
two relays were hot to the touch replaced them and car did the same took the panel out of casing & it was shorting at this point replaced that so far so good.
Thanks, i hope i don't have 2 go thru this again, the car will definetly go to a qualified mechanic.
