Jim's avatar
Jim
Toad questions...
After 12 years of RV'ing I've finally upgraded my RV to a '02 Journey with a 330 HP Cat. Also just bought a 2001 Saturn LS1 as a towed. I'm in Portland, Oregon and a local trailer business is an authorized installer for Blue Ox so I've made an appointment to have the Ox base plate installed there. Cost is $394 parts, and $275 flat rate.
The RV came with a Blue Ox tow bar, the RV has a 7-pin connector with a funny 6-pin electrical drawing that I suspect is just a mistake on engineering's part, and there's also a braking system.
I plan on installing the electrical in the car myself since there's where my training is, but wonder what you folks that have done the wiring yourself used for parts or kits.
The Saturn has separate brake and running lights, backup lights, etc., and I probably need to add a switch for the 30 amp fuse Saturn recommends I remove.
Any thoughts on electrical setup with this car???
Thanks in advance.
  • Jim,
    If your Blue Ox system is of the same vintage as mine, it does use a seven pin to six pin umbilical from the motor home to the toad.
  • I installed a base plate myself in a Hyundia and I used diodes for the lights. 6 diodes, two for the left turn/brake, two for the right and two for the parking lights. I got a flat four wire and ran it to the front.
