stugpanzer wrote:
Should I presume that all the recommendations would be standard transmissions? This is an area I will need education in. I can drive standard, no problem there just wondering if some automatics can just be put in neutral.
generally, jeeps with automatic teansmission and a manually selectable neutral position in the transfer case can be flat towed. regardless of make or model check the owners manual to be certain the vehicle can be flat towed and what the setup procedure is. be aware that some vehicles come with time, speed and/or distance restrictions. and lastly, the amount of weight you can safely tow will be the lesser of the following:
- the gross combination weight rating of the MH minus the actual weight of the MH as it is loaded and configured for travel
- the weight rating of your hitch
- the weight rating of your tow bar
