oldtrucker63
Jul 20, 2011Explorer
My Tank is Plastic and it is about 45 gallons, It takes up all of the room under there It fits tight all the way around, Don't know about the TQ Carb It runs perfect, It seems like back in my Hot Rod days I remember a fuel pump that had a bad gasket and caused the gas to drain back to the tank, It was like a pin hole in a Diaphragm If I remember right, But that was a small block chevy, But I do believe the inside of the pumps is built all on the same pattern, Maybe someone out there knows if the inside of the fuel pump has a Diaphragm inside that can cause this, I hate to rebuild a Carburetor if it don't need the kit, Maybe a easy way would be to hook a electric fuel pump to it and see if the fuel will stay up, Thats the only thing I can think of.
38,777 PostsLatest Activity: May 24, 2026
