oldtrucker63
Jul 21, 2011Explorer
TreeSeeker wrote:I will supply power to the fuel pump by the key switch, And a Toggle switch also, Just because I have some extra lighted toggle's and with one more lighted up will just look good.Skimask wrote:
I added an oil pressure switch as well as a manual power switch to control power to it. Just a regular ol' 5-7psi $30 fuel pump.
I assume that the oil pressure switch is to cut off the fuel in case of an accident (instead of an inertia switch)? I am also guessing that you need a manual override to get the engine started since there is no oil pressure before the engine starts? So you turn on the manual override until the engine is started, then turn it off? If so, that does seem prone to accidentally leaving it on.
Inquiring minds want to know...
38,777 PostsLatest Activity: May 24, 2026
