oldtrucker63
Aug 23, 2011Explorer
skimask wrote:10/4 Thanks I will check and find out just what I will need, I would like to have it like the house thermostat or say like the one for the furnace that is on the wall.oldtrucker63 wrote:
Do they make a wall thermostat that will handle that voltage.??? I will check it with my meter to see what kind of Voltage/amps go through it.
The thermostat wiring will be the full ~120VAC/high-current. But I was thinking more in terms of mounting one of the thermostats like the one in your A/C in a box and mounting THAT on the wall. It won't be calibrated just like it isn't cal'd now (i.e. won't be marked in degrees and such), but it should work.
If you're thinking more along the lines of like what your house has, that'll take a bit more work (i.e. standard thermostat, 24v power supply, a relay, etc.etc.etc) but I think it could be done without much problem. Just gotta round up the pieces/parts.
38,780 PostsLatest Activity: Aug 05, 2026
