oldtrucker63
Aug 27, 2011Explorer
falconbrother wrote:I think so too, I believe it's about the same as the JB weld only JB weld is good to 600 Deg. and this fire seal is good to 2000 Deg. It should work, I'm going to grind the pitted area down just a little and then apply this fire seal, After it is good and dry I will then apply the Calyx to both manifolds, Then there is no worry's about any more Rust....Ever.
That stuff sounds pretty interesting. Might work for you. Over the years for various kinds of repairs I have used JB Weld. It has worked amazingly good. This stuff will likely do a good job for you.
38,780 PostsLatest Activity: Aug 05, 2026
