oldtrucker63
Sep 01, 2011Explorer
KelliL wrote:Something was wrong, The eternabond can not be stretched when applying it, Some people stretch it when they put it onto the body/roof and this will cause it to come up and not stick good, I know the cloth backing roof seal that I used is great and I don't think it will ever leak, Now the window seal eternabond that has the thin plastic film there after you stick it on, It is a clear plastic, That kind is not any good for anything other than sealing windows, And I don't mean sealing windows like where you would use the gray putty, It is for sealing around a window like a house window, I used it to overlap the window frame, Like 2 inch outside and overlap 2 inch inside and then set the window in and seal the window with double sided eternabond, So with that said I think other than the window seal, ALL of the other eternabond works really great. Just don't stretch it when you apply it.:B
I used regular Eternabond on my RV and was less than impressed. There are spots where it doesn't stay stuck down (it peels up). Guess I should have spent a little more and tried the cloth stuff.
38,780 PostsLatest Activity: Aug 05, 2026
