Replant
Sep 06, 2011Explorer
oldtrucker63 wrote:tboss wrote:Hey thanks tbos I will try that, Just by looking at the rubber seal that is what is leaking.
Hey driver if the leak is the same as mine was and it sounds like it is,, you will have to remove the rear window and take the glass out and reseal around the glass and the frame ,,be sure to clean the glass real good or it will leak agn,, it ws not to bad of a job ,,its just time consuming...good luck..
I think it's PermaTex that puts out a clear liquid windshield sealer in a small tube that does a great job of sealing the rubber gaskets. Just run a bead along the seam and it will find the leak and seal it. No fuss no mess.
38,780 PostsLatest Activity: Aug 05, 2026
