skimask
Dec 03, 2011Explorer
oldtrucker63 wrote:
I bought it with the transmission leaking fluid out from the front, It will shift through 3 gears but would not go into OD
Don't know how much you know about these transmissions, but failure of OD in a 4L60E (most likely your tranny) is likely a cheap fix, a solenoid, speed sensor, OD switch (if equipped), and a half dozen other things.
If reverse and 2nd work fine, chances are your fix will be a cheap one and not require a full-blown rebuild.
38,780 PostsLatest Activity: Aug 05, 2026
