oldtrucker63
Dec 07, 2011Explorer
skimask wrote:Yes its a rush, Of fluid, Not a drip like the front seal being bad, The Thrush washer is bad to slide forward in the 4L60E transmissions and when it slides froward they leak bad, I dont know if that would cause it to not go into OD cause the OD is Electric and I think a bad Solenoid would hold it out of OD, I will be doing some you-tube videos on rebuilding the 4L60E the right way, It will be about a 4 or 5 part set of videos.
Ah...good...I'm speaking with experience. (doesn't happen too often ya know)
Yep, I didn't pay attention to the "leaking fluid out the front" part. Is the leak really that bad? I've seen a couple leak and they've been light drips, not a full on fluid rush. You think you're losing enough pressure to keep it out of OD?
38,780 PostsLatest Activity: Aug 05, 2026
