tenbear
Feb 21, 2012Explorer
oldtrucker63 wrote:
On these RV Toilet's...??? When you add water to the bottom of the bowl
How long should should that water stay in the bowl.??? It has been 15 minutes and there is still water in the bowl but it did leak through when I first poured the water into the bowl, I Might have poured to much water into the bowl and made it leak a little, Or should it hold the water.???:h
It should stay there long enough that the seal never gets dry. A couple of years ago mine started to leak. I took the seal out and cleaned it, scraped some mineral deposits off. It now works like new, holds water all winter. Yours should too.
BTY, its good to see you back at work on the rebuild again. Looks great.
38,780 PostsLatest Activity: Aug 05, 2026
