14yuTrk
Mar 12, 2012Explorer
lzasitko wrote:
To split the gutter you could use a table saw, with one side against the fence it should be pretty precise. A sharp Carbide tipped blade would give the cleanest cut, though I have used a fine wood blade with acrylic plastic and so long as you don't feed it too fast it is good.
Table saw should work, just make sure the blade is just high enough to cut through, otherwise it will shatter the edges.
38,780 PostsLatest Activity: Aug 05, 2026
