oldtrucker63
Apr 05, 2012Explorer
MMarieT wrote:Yes that is correct,
Rebuilding the entire motor section of the class c we have...it was so rotted we have decided to take it on and redo it...anyone out there please tell me how did you attach the over the cab section on your rebuild of your class c motorhome since that area is wide open now that it is stripped waiting to be built; so that there is enough support for the bed and to make sure there will be no chances of leaking....we are building our living quarters directly on the frame of the truck...will be fiber glassed on the exterior of course, which is another question...the over the cab section belly should be glassed before final attachment, right, so the exterior part of the over the cab section should be glassed before assembled in order to not have to try to reach under it...is that correct?????
On mine it has a steel frame all the way around the RV and the overhead bunk area and when I ran the wood frame I used 5 inch bolts and went through the 2x2 the steel frame and the other 2x2 on the back side, So there is two 2x2's with a steel frame in the middle of this with long bolts through all three.
