rehoppe
Apr 23, 2012Explorer
In regards to the inverter. If you connect it to the 'battery' side, when you turn off the 'battery' disconnect switch, it'll kill all battery drains. You do have do look at the 'charging' situation as to what and when you go to 'charge', or power up with 'shore power'. A bit of forethought will serve you well. It is a good idea to dump the loads when you're leaving it sit idle at home.
But I expect that you've already thought of it and wired accordingly. So just FYI for others.
