oldtrucker63
Apr 28, 2012Explorer
Ran the gas line for the generator today and it would not pump any gas through the line, OK The fuel pump quit so I bought a new fuel pump and still no gas, I could blow through the line but no exhaust on the line so I took the tank off and found that the end that was on the line tube had some kind of one way valve on it, I removed it and now it works fine, Only I had just went and pumped 27 gallons of gas into the tank just before I installed the generator's gas line and with no way to pump the gas back out I took the tank off with the gas still inside the tank, It will be a Bit*h to put back but I will get it there some how...........:S That is just part of a rebuild............I ran the generator with the tank out on the ground and I had to re-adjust the choke and idle because when the roof AC kicked on and ran on cool for a few then it would kick off causing the generator the run pass the 1800 RPM limit causing it to shut down, Its fixed now and running great I just need to install the gas tank tomorrow.
