oldtrucker63
May 21, 2012Explorer
wareagle11949 wrote:Not really because this is an open circuit voltage chart, The 12.2 volt reading that is on my volt meter in the morning is with the fridge still running so there is still a load on the battery, If I unplugged everything then the volt meter would then rise to a higher reading.:h
Tree Seeker is correct. Until I started messing with electric golf carts, I thought 12 volts was good to go. Here is a chart that is helpful.TreeSeeker wrote:Oldtrucker63 wrote:
My Volt meter reads 12.5 with a full charge in the battery, If I turn on only one light it will drop to 12.4 When I ran the fridge all night the next morning the meter reads 12.2 volts, with the generator running or when plugged into shore power the meter reads 13.6 volts, I ran the fridge all night and the battery was still just about a full charge, It took very little to run this fridge all night.
If I understand what you are saying that the voltage was 12.2v in the morning, then the battery is half discharged (not "just about full charge") and you are not supposed to discharge a battery more than this. So, you are only getting less than 24hrs of run time (fridge plus whatever else you were using) before the battery needs to be recharged. I don't know what the charge capability your system has, but my 35amp smart charger takes 4-6 hours to recharge a battery from half discharged.
Here are some articles about RV electrical systems that may be of interest:
BATTERIES--AND OTHER ELECTRIC STUFF
The 12v Side of Life
Intro to Dry Camping
Battery Education
But none the less this is a great chart to have,...Very helpful Thanks.
38,782 PostsLatest Activity: Aug 23, 2026
