RVER's avatar
RVER
Touch up paint
Where do I start to get the touch up paint for a Newmar Mountainaire 2003 gas with two tone green paint. HUGE amount of pits on front of the rig, amazing, maybe 100 or so little chips. HELP with getting a touch up paint for this job.
  • Check through the documentation for paint codes. The code for our Landau is on the build sheet glued inside a closet door. With that code, I was able to search online and determine that certain year Chrysler vehicles used that color. With that information, there are online sources for custom mixed brush and spray touch-up paint. I used AutomotiveTouchup.com and was very pleased with the service and color match. Local body shop paint suppliers usually can also custom mix paints by paint code, but may not be willing to do small touch-up quantities.
  • YES thanks, was just hoping there was a paint I could buy around here but you are right, call NEWMAR
  • If not try calling some automotive paint suppliers and see if they can color match it for you. Many paint stores have color analyzers and can do it right in their parking lot.
  • Call Newmar and give them the Vin number and they probably can supply you with original color touchup.
