bsport
Apr 19, 2015Explorer
tow bar base plate
Will a tow bar base plate from a 2005 jeep Rubicon fit a 2015 jeep Cherokee? And is camping world a good place to have the work done? Thanks' BOB
bshpilot wrote:A 2015 Jeep Cherokee is NOT a JK. Totally different vehicle and platform.bsport wrote:
Thanks' BOB
97-'06 is a TJ
07-present is a JK.
i would NOT expect TJ base plates to fit a JK.
beginning w/ 2012 the JK frame extensions changed every so slightly (slight modification/trimming) needs to be performed so that earlier (JK) base plates will fit.
beginning in 2012 to present there is also a vac pump mounted on the frame extensions (behind the bumper) that needs to be relocated (not a difficult job).
