Dutch_12078 wrote:
We had a similar genny exhaust issue with our Protect-A-Tow, and my fix was to cut the pipe back a bit and add a 90 deg elbow to bring it out the side. I did consider a fix similar to yours, but the elbow also put the pipe in a better location for attaching our Genturi exhaust extender.
Dutch - Thanks and I have purchased the elbow and all the stuff needed to make that type of change. In the end I opted for the shield as I was a bit concerned about exhaust fumes near the rear bedroom was unsure where those fumes would end up. Sounds like you have used it safely and well- so I may try that at some point. At the moment this set up seems to be working well.
One other point is that I have not had a problem nor have I used the Protect a Tow on the good interstates of the lower 48. Thus far I have found no damage to the toad running in the lower 48. If I run across an interstate or a back road with loose gravel though I may slap it on quickly as it takes about 2 minutes to attach.
Rascal
