Diane and I plan to buy an RV motorhome Class A. Very new to this venture and experience. We need your help. The tow capacity of the Class A Motorhomes vary from bus to bus. My question is, is the rat...
You'll need to do a bit of home work to ensure the coach you acquire can safety perform what you are demanding. Towing a full size pickup with a heavy bike in the bed pretty much pushes you into diesel territory. Search for a coach with an Allison 30000 transmission then check available combined weight capacity. The weight sticker on the hitch is no guarantee a coach can actually tow that much. You have to run the weight numbers.
