Frosty10 wrote:
kidkasha wrote:
can someone please tell how I should go about putting a 4 down system together for my Ford Fusion and exactly what I need and the approx cost. I am a little slow so please be patient.
Arnold
I don't think the 2012 Fusion is approved for four down towing. Ford had too many transmission fail so they stopped approving the Fusion. The hybrid might be towable.
You need to check with Ford to be sure.
This is the first thing you need to do. There may be a section of your owners manual that tells if you can even be towed or not. If it can't, then you have an added expense of a drive shaft disconnect or transmission cooler. For me that would be a deal breaker. I'd go with the dolly.
