Trackrig
Sep 02, 2017Explorer II
ricelake922 wrote:
So Bill you are saying to use a ratchet strap that does not have the sides that holds the tire better in place. Is this correct?
Yes. I've seen them used on some rigs. Try it, see how it seems to fit. Go a ways an check it. Near the front bumper is the frame hook that the car shippers use to secure the car? If so, when you by the two inch yellow strap, they usually come in pairs. Use the second one from the bump hook to someplace on your dolly for added safety.
You towed it a ways with only one strap, and by no means am I telling you to do that, but try the single wide 2" strap and see what happens. Check it often until you get a little confidence in it.
Don't forget to deflate the tire some.
Bill
38,782 PostsLatest Activity: Aug 30, 2026
