ron_dittmer
Jul 29, 2013Explorer III
Tow Vehicle - Front Tire Wear Issue
We tow a 2006 Jeep Liberty 4x4. I have noticed that after towing it, the Liberty's front tires rumble. So I've spun the tires on a balance machine and found only those two front tires have significant flat areas, I assume created when being pulled into turns from the motor home. The flat areas are not flat to the road, but consistently favoring the outside portion of the tire. That rules out an over-aggresive tow brake. The flat areas can measure numerous inches in size, not chaffing as is common with a poor wheel alignment of poor balancing. The Liberty's wheel alignment is good, and tires properly balanced prior to the beginning of the trip. The steering wheel is always unlocked and seems to track well when being pulled around in turns. The tow vehicle follows calmly behind the motor home, never dancing back there as my backup camera watches it well.
This is my second set of tires. The problem has been the same with both sets, but with just the front tires after being towed. Rotating the tires yield 4 tires that rumble after the next towing experience.
Has anyone here experienced this with their tow vehicle? If so, have you ever found a reason for it, and can offer a solution? Please don't mention a tow dolly here.
