rk911
Nov 02, 2016Explorer
PNW Wood wrote:
Hi,
New member first post. Never had a MH and we are thinking about what it looks like to be an owner. I've read through some of the intro's and FAQ's, thank you so much for taking the time to put all that information together. I'll refer back to it numerous times I'm sure
We plan to buy a house in Mexico, along the Pacific Riviera between Mazatlan and Puerto Vallarta. The discussion as it goes right now is to spend 8'ish months down there, then come back into the states for 4'ish months. We have family in Pacific NW and Texas (and AZ actually). We'd spend the June through Sept months in the states visiting family, staying away from the intolerable heat of coastal MX.
Having an RV and using that as home base when we are in the states seems to make a lot of sense to us. It allows us to bring our dog, car, etc., not have to pay for a place in the states, blah blah.
In the research I've done so far it seems ULSD is not an option in Mexico and it seems it won't be for an undetermined amount of time... so that puts me in the gas world. Fine
I plan to tow a Jeep. My impression from what I've been able to glean so far, is only the tongue weight ads to the cargo payload? Can someone confirm this? Other weight issues for towing is simply to make sure the hitch is rated to handle the weight of the toad???
For those with gas rigs - is cargo weight a constant balancing act? It seems like there are real narrow margins when it comes to the gas rigs. We aren't hauling kids and toys, but I imagine with all the variety of things you can take... camp gear type stuff, that all ads up quick. Have you gassers had buyers remorse for always being up against capacity?
So far the Coachman Mirada and Fleetwood Bounder or Flair have interior layouts that look attractive. I've not sat in any yet, just looking at floorplans and pictures. Any comments from owners on these manufacturers and models?
Thanks for feedback. Sorry for the long post, figured some context on me and our plans might help with your answers
no worries. you are wise to ask these questions.
interior layouts or floorplans are important, no question about it. but you also need to understand your motorhome's actual weight and weight ratings. doing that will ensure that you do not overload either axle and that you can safely tow a car or trailer.
the RV industry has created plethora of weight ratings but it all boils down to this:
GVWR (gross vehicle weight rating): this is the total amount of weight the MH chassis can support including itself.
GAWR (gross vehicle axle rating): this is the total weight each axle can support. each axle will have a different GAWR, usually, but not always, the GVWR will be the sum of the GAWRs.
GCWR (gross combination weight rating): the total weight the MH can propel including itself. the GVWR + the weight rating of the hitch is usually, but not always, equal to the GCWR. for example our MH has a GVR of 26,000-lbs and a 5,000-lb hitch but the GCWR is 30,000-lbs.
Empty Wight: the weight of the MH as it came from the factory. No fresh water, LP, food, etc.
Payload: the difference between the GVWR and empty weight (per axle). this will tell you how much weight you can add to each axle.
GVW (gross vehicle weight): the total weight of the MH as it is loaded for travel. this includes full fuel, water and LP tanks, food, clothing, supplies, gear, pets, people, stuff, etc.
GAW (gross axle weight): same as above except the total weight on each axle. the sum of the GAWs will be the GVW. it's important to get individual axle weights as it is possible to be underweight on one axle, overweight on the other and still weigh less than the GVWR. I know this from personal experience.
it may sound complicated but it really isn't. the dealers will quoye you all sorts of other weight ratings such as CCC, Sleeping weight, wet weight, etc. stick to the basics and you'll be fine.
in terms of towing, once you know the GVW of the MH you can determine just how much weight you can safely tow be it car, dolly or trailer.
in general, the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, etc.)
- the weight rating of your tow bar
- the weight rating of your hitch
good luck.
38,782 PostsLatest Activity: Sep 02, 2026
